Thread: Sweet spot
Old 07-02-2011, 11:50 AM   #7 (permalink)
user removed
Load is better determined by MAP or the reverse vacuum. It is independent of throttle position as I stated in my previous post, if you go from flat ground to an uphill grade then the load increases and vacuum drops, while MAP (the inverse of vacuum reading) increases.
regards
Mech
