Old 07-02-2011, 05:47 PM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by bkalina View Post
How skinny can a person go when using the stock 14" rim?
Depends on the rim width - probably 5 to 6 " .
If you get that width number off the rim, you can check wether a certain tire size will go onto that rim using one of the online tools like
Tire Size Calculator - tire & wheel plus sizing .
This will also give you some good ideas about tire size availability and difference in diameter, so you get an idea of how much extra space they need in the wheel arcs.
If you want to go narrower, the 175/80R14 is an option but its circumference is over 6% bigger, and that's a lot.
Quite a few people on the forum have reported losing mpg when installing oversized tires.
175/75R14 wouldn't be as agressive an increase, but tire choice seems rather limited (van tires).
