LCD connections are not related to ISO or CAN protocol - I assume you mean the OBD connections and not LCD?
Taking current from the 7805 (or adding your own) should be better, the pins I've seen are rated to 40mA (the digital pins, I'm not sure if it applies to the 5V, probably wouldn't harm anything).
