Old 07-05-2011, 09:00 PM   #13 (permalink)
Frank Lee
Originally Posted by Shinjitsu View Post
It would make sense that it would be at least somewhat functional. Most of us know, and if you don't your about to, that the wheel wells are an area where air is slowed down because of drag which makes that area a high-pressure area of the car. If you ever drive behind someone in the rain you can see the effects of this b/c there it a ton of mist and rain flying out of the wheel wells. So these body lines could be trying to suck that air out a little more and guide it to the place it is needed most - where the rear of the car creates a vacuum. If they can feed more air softly around the rear of the car, they can fill in part of that vacuum that is basically sucking the car back. Then again, the body line has been around for a while so it could just be a trend.
You get the prize for having the most vivid imagination.
winkosmosis (07-05-2011)
