Old 07-06-2011, 01:02 AM   #23 (permalink)
ChazInMT
Aero Deshi
ChazInMT's Avatar
MagMetalCivic - '04 Honda Civic Sedan EX
Last 3: 34.25 mpg (US)
Originally Posted by winkosmosis View Post
They're not mounted backward. The big end is flat, not aerodynamic in any way. Air would hit that surface and spill out to the sides, effectively making a much bigger frontal area.
Ya know, for someone who's been around a while you still aren't getting it. Believe what you want about the front end needing to be not flat, fact is, the air creates its own aero shape in the front. In the back of a shape, the air gets really stupid and needs much help. Intuition tells us the air gets "spilled out", fact is, it does not. Granted, an aero front end does help some, but not as much as the back. I'd say it's a 20/80 split at best, 20% front and 80% back as far as how much you can improve the aerodynamics of something by improving its shape.
We aren't saying the carriers would be optimal by reversing them, only better, because that nice aero taper on the "Front" would bring the air back together much more efficiently, if reversed, than the big wide flat back it has now.
I made a simple drawing to illustrate what I mean.
