Old 07-06-2011, 09:58 AM   #1 (permalink)
wclement7
Car - '96 Ford Taurus GL
After Install Questions
Finally found some time to install my mpguino and it works! YAY
Some questions I may or may not be missing the in wiki...
I understand it needs to be calibrated, but should the speed be off my 50+ mph the first use?
My gauge shows zero mph and mpg until i get over 15mph, is this normal? Or do i need to use a smaller resistor on the vss?
This needs to be always powered or it loses settings etc, is there a way to have the backlight turn off after a certain amount of time with no vss or injector signal?
Thanks for the help everyone!
