Old 07-06-2011, 04:08 PM   #23 (permalink)
Phantom
Phantom's Avatar
Blue Meanie - '02 Volkswagon Golf TDI
90 day: 48.52 mpg (US)
Wife's car - '05 WV Passat TDI
Rudy - '94 Chevy C2500
It sounds like what the dealership is using is similar to GMs TechII that can change some parameters.
Changing the idle speed can be done via a remap on most ECUs and should have a few lines in the table. On the cars (gas) that I have looked at they have the following:
The Y-axis is:
AC off in drive
AC off Neutral/Park
AC on in drive
AC on Neutral/Park
The X-axis is:
Coolant Temp
The corresponding cells contain the desired idle RPM. This way the idle will be higher at low temps drop down at operating temp then rise a bit at high temp to spin the water pump more for cooling. Also it will bump the RPM up a bit when the AC is on.
I move at the speed of awesome.
"It's not rocket surgery!" -MetroMPG
