Old 07-07-2011, 05:10 PM   #27 (permalink)
winkosmosis
Originally Posted by ChazInMT View Post
Yeah, OK. You go focus on the front end of things then, see how that works for you. I say the car carriers will work better going the other way as do most people in here. I guess we have all just drank up too much of the Koolaid.
I would go into more detail as to where it seems you are confused about things, but the tone of your posts is not conducive to me wanting to help you out. Figure it out on your own.
You're still not applying common sense, just parroting tropes. "Front end doesn't matter, front end doesn't matter, squawwwk!!!"
Your diagrams are WRONG. Period. You really think you're smarter than NASA and that a Hummer is aerodynamic even with its sharp corners, because air is magic and forms the most aerodynamic shape, allowing nice smooth transition to the sides of the body?
Maybe you should call up all the truck manufacturers and tell them that they don't need air deflectors because "what the air is doing" is forming the exact same aero shape through the force of magic! Oh and don't forget to say "Front end doesn't matter, front end doesn't matter, squaaawwk SQUAAWWKKKK!"
