Old 07-08-2011, 02:03 PM   #14 (permalink)
Execut1ve
EcoLurker
Execut1ve's Avatar
truck - '94 Ford F150 XLT
90 day: 13.15 mpg (US)
civic - '00 Honda Civic EX
90 day: 36.24 mpg (US)
you are referring to your setup where you had stock wheels/tires on one hand and taller tires/larger wheels on the other, correct? and you found that the taller tires more than made up for the extra weight of the larger rims, if I remember rightly
when stepping up to the taller/wider tires did you have any troubles with rubbing with the steering wheel at full lock? or tire hitting the inner fender after a big bump?
