Old 05-11-2008, 04:16 PM   #58 (permalink)
Cowspots
Eco-Nerd
Weight penalty & slow rpm?
Friends,
I can't help but wonder what the dimensions and weight are of the Yanmar and Iveco diesel engines. Additionally, I am curious as to the RPM/power curve and would love to see ALL of the specs.
I have been monitoring this thread for some time now and also have been in contact with VW technical support. I have owned or driven four diesel passenger cars and currently am dismantling an Iveco Z-100 powered by a Duetz 5-Cyl air-cooled diesel engine. I planned to install the Duetz into a GMC Dually that had previously been home to a 454 to do my heavy hauling as this Iveco chassis is a poor restoration candidate due to parts availability. Unfortunately, the dimensions and weight of the engine also made that an impractical swap.
Enough background and back to the topic: At this point I believe that the lightest, most versatile and cost effective engine for any diesel hypermileage project is the VW 1.9L TDI system. I owned an '02 Jetta TDI and with Upsolute ECM & boost modifications I was able to increase mpg from 46hwy to 53hwy using premium diesel.
I recently contacted VW and they informed me that the '09 Jetta TDI SportWagon will not have BlueTech UREA injection. This was misreported in an automotive magazine that I read. I don't want to be held prisoner by the EPA to buy a UREA solution from VW & Mercedes at some insane markup price that already adds to the fabricated diesel cost penalties. If I do purchase a new car again, this is the most likely candidate.
In the meantime I will stick with my 35-50mpg Metros as the fuel is $0.50 less per gallon.
Furthermore, I have ridden in Corvettes and visited the plant in KY and cannot see ANY practical application for this automobile - only vanity. Putting a 3-cylinder diesel engine in a 'Vette, which does not have the best aerodynamics, just isn't practical for anything except mileage runs. If you are lucky enough to be able to blow that kind of cash, why not use a 2-door 4-seater with better aerodynamics like a Firebird?
After all is said and done I'll bet that my nearly stock Metro will blow it's tires off for best performance, lowest cost to build, smoothest operation, lowest cost of operation and finally practicality. I can take a friend and my dogs out to the park in it too.
Ok, so I might be playing Devil's Advocate or just acting like a turd here, but it's my two cents and this is a forum isn't it?
Good luck on your projects and I hope that your investment will be rewarded with more than bragging rights.
Cowspots
