Old 07-09-2011, 10:32 AM   #29 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
A sharpie marker does wonders when indexing spark plugs so you can keep track of the ground leg while threading the plug in and if you are unsure where your valves are in relation to the plug then you should be able to find a photo of your head online or even in your shop manual.
Originally Posted by Execut1ve View Post
someone above mentioned indexing the plugs. I'm familiar with the basic idea, but wouldn't I have to have the head off the engine to see where the intake valve is to make sure the ground strap is on the side opposite the intake valve?
