Old 05-11-2008, 06:57 PM   #22 (permalink)
JohnnyGrey
Pushrod - '02 Chevrolet Cavalier
Yes, P&G will net you greater results than cruising, lean burn or not. That's because you're dumping most of your fuel in a good BSFC region at aerodynamically efficient speeds. When you can no longer sustain those speeds, you lay off the gas and repeat.
