Old 07-09-2011, 01:26 PM   #42 (permalink)
glug
Originally Posted by dcb View Post
Glug, you might just need a simple "amplifier" upstream of the guino, i.e.
It would be good to know what your car vss signal looks like under different conditions though and adjust the resistors accordingly.
Thanks for the suggestions!
Looking back in this thread, I did omit mentioning the voltage of the sine wave from the reluctor. I think I have since lost those notes. I recall that in the 0-250 hz range, the voltage tracks fairly linearly from 0 to 2.5 volts. Recall that my sensor is about 10hz per mph. So it is approximately 1 volt per 10mph. The quality of the sine wave is excellent when I record it with an audio recorder - the samples are clean and consistent, etc.
So using a PC soundcard output as a signal generator seems like a good approximation at lower speeds.
It would be a nice surprise if that simple amplifier would be sufficient to solve these detection issues. I have some 3904's, so I'll give it a try. I also have a couple of 74AHCT74 ICs, and just need to assemble my test circuit.
