Thread: Disc brake drag
Old 07-09-2011, 07:43 PM   #44 (permalink)
momorris
Been having a nightmare with brake drag this weekend. Cleaned sliders, changed hose. At the moment it looks like the internal piston seal has swollen in the caliper that was dragging.
I swopped the pistons and seals over from passenger to drivers and vice versa to see if the problem also moved. While doing this I compared the seals and one was definately larger. Doing some more research it could have been caused by the garage using coppergrease instead of silicone or red brake grease.
