Old 07-10-2011, 07:58 PM   #4 (permalink)
Frank Lee
Originally Posted by Ryland View Post
I haven't seen an alternator with a fan on it for years, so if your field windings are turned off then the only drag on the alternator are the carbon brushes, the bearings and the rotor, adding a clutch you will be adding another set of bearings, more rotating weight and more air drag.
Oh, they still have fans; they've just moved inside the housing (probably for noise reduction). Except for the liquid cooled ones.
The only potential savings I see from a clutched alternator are from not spinning a cooling fan. The added drag from the clutch itself may cancel out even that meager benefit.
