Old 07-11-2011, 02:26 AM   #4 (permalink)
phunky.buddha
Blow stuff up
phunky.buddha's Avatar
S2000 - '03 Honda S2000
90 day: 24.42 mpg (US)
How do you figure your compression is higher than stock?
You can run 185/65-14 on the Insight wheels.
Have you calculated your mileage adjusting for the larger tire? Your stock size is 185/60-14, so if you're not compensating for your larger tires, you're actually doing better on fuel economy than you think you are.
Intercrew Auto Salon
