the last version not is v140¿?
[Get email change notifications about comments on this revision.] r140
Made the iso_init function more robust
May 21, 2009
matthews.mike
[Get email change notifications about comments on this revision.] r127
Will now clear current outing when the car starts running, not when the car engine shuts off
Mar 28, 2009
matthews.mike
[Get email change notifications about comments on this revision.] r126
Fixed Engine Breaking. Remove the fuel wasted display for ELM so it will fit. (ELM uses about 330 more bytes of space) Added some new PID's that will display stats for your current outing. rests every time the car is turned off.
Mar 13, 2009
matthews.mike
[Get email change notifications about comments on this revision.] r125
forgot a line to reset fuel wasted
Mar 5, 2009
matthews.mike
[Get email change notifications about comments on this revision.] r124
Turns the backlight off when the engine is not running.
Mar 5, 2009
matthews.mike
[Get email change notifications about comments on this revision.] r123
Added tracking of wasted gas. Modified iso_read_byte() to return a response if nothing is received so program doesn't get stuck. Fixed math for fuel consumption.
Mar 5, 2009
matthews.mike
[Get email change notifications about comments on this revision.] r122
add fuel and speed adjust
Mar 4, 2009
tiange
[Get email change notifications about comments on this revision.] r112
correct ISO init
Dec 18, 2008
tiange
[Get email change notifications about comments on this revision.] r110
some optimization
Dec 5, 2008
tiange
[Get email change notifications about comments on this revision.] r101
correct warnings
Nov 5, 2008
tiange
[Get email change notifications about comments on this revision.] r100
add a trip for tank and a trip for trip
![Smile](/forum/images/smilies/smile.gif)
Oct 16, 2008
tiange
[Get email change notifications about comments on this revision.] r99
add fuel used and remaining distance
Oct 15, 2008
tiange
[Get email change notifications about comments on this revision.] r98
float to long, gained about 1500 bytes!
Oct 10, 2008
tiange
[Get email change notifications about comments on this revision.] r95
optimize some code, change contrast
Oct 9, 2008
tiange
[Get email change notifications about comments on this revision.] r94
optimize some functions and correct imperial display
Oct 8, 2008
tiange
[Get email change notifications about comments on this revision.] r93
correct avg trip fuel string if reset not moving
Oct 6, 2008
tiange
[Get email change notifications about comments on this revision.] r92
correct avg fuel consumption
Oct 5, 2008
tiange
[Get email change notifications about comments on this revision.] r91
correct MPG calculation
Oct 4, 2008
tiange
[Get email change notifications about comments on this revision.] r90
optimized some calculation
Oct 2, 2008
tiange
[Get email change notifications about comments on this revision.] r87
Configure PIDs as an option in menu
Oct 1, 2008
tiange
[Get email change notifications about comments on this revision.] r86
SVN test
Oct 1, 2008
tiange
[Get email change notifications about comments on this revision.] r85
SVN test
Oct 1, 2008
tiange
[Get email change notifications about comments on this revision.] r84
replace corrupted copy
Oct 1, 2008
tiange
[Get email change notifications about comments on this revision.] r82
Add version numbering Stable version
Sep 30, 2008
tiange
[Get email change notifications about comments on this revision.] r81
debug simulation mode
Sep 29, 2008
tiange
140 - 81 Older ›
