dcb,
Are you taking injector offset into consideration? I did not see anything in the setup where you require a user to input the injector offset... Taking that value into consideration may help increase your accuracy in Peak & Hold injectors as well as some other more common modern injectors like high volume flex fuel injectors that have more radical injector offsets.
To engine calibrators, this value is critical in accurately predicting actual fuel mass injected when dealing with different fuel injectors on the same engine. Likewise, I would think it would be mandatory to accurately calculate fuel consumption when monitoring the injector input.
