Old 07-12-2011, 04:26 PM   #2 (permalink)
ecofreak
Aspires, from what I can tell, have their own sort of kammback built in. If I was in your position, I'd say my best bet would be to begin with getting a feel for the car, while beginning to consider the mods.
Making a more pronounced kammback would be good, as you could then consider a boat tail. Grille block, belly pan, and wheel covers are also good investments.
You mentioned making a boat tail from DOM steel tubing. Might I suggest EMT (or any sort of thicker walled, aluminum variant) conduit? For me, it's cheaper, lighter, and a lot easier to work with. It's rigid, self-supporting, and forgiving; for me, permanence would be bad if the tail sustains enough damage.
