Thread: 1,180 Mile Tank
Old 07-13-2011, 11:45 AM   #13 (permalink)
Diesel_Dave
Diesel_Dave's Avatar
White Whale - '07 Dodge Ram 2500 ST Quad Cab 2wd, short bed
90 day: 37.68 mpg (US)
Yeah, heaters are one of the next thing on my list of mods. Coolant heater will be the first because it's already on the engine. All I had to do was get the cord for it ($15 on Amazon). I have the cord now, I just need to screw it on. The thing is I can reach the heater hookup (with my hand), but I think I'll have to take the oil filter off to actually get it off (which I have to do shortly anyway because I'm overdue for an oil change).
I'm looking into using the coolant heater for a few reasons. Since we moved, my commute is now 25 miles rather than 40, so the warm-up time affects me proportionately more than it used to. I started carefully watching my coolant temp warm up times after I intalled the upper grill block. In the morning, with the ambient temp 60 to 70 F, it still takes around 2 miles before the temp gauge moves (140 F) and 10 miles before I get up to 200 F coolant temp. Once I get up to temp the FE definitely improves.
What I don't know is how much of the FE warm-up penalty is the coolant temp vs. oil temp vs. tranny temp vs. axle temp, etc. If I had to guess order of importance is oil, coolant, tranny,axle, but that's just a guess. Of course if I pre-heat the coolant then my oil should warm up faster as well. Eventually, I'm thinking up getting some of those pad heaters for the oil pan--maybe even the tranny & axle too (we'll see).
BTW, anyone know the cheapest way to monitor temps (oil, tranny, axle, etc.)?
Diesel Dave
My version of energy storage is called "momentum".
My version of regenerative braking is called "bump starting".
1 Year Avg (Every Mile Traveled) = 47.8 mpg
BEST TANK: 2,009.6 mi on 35 gal (57.42 mpg): http://ecomodder.com/forum/showthrea...5-a-26259.html
