Old 07-13-2011, 01:36 PM   #351 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by apowers View Post
Yes I think it is a transforner. I'm not sure I can use it for anything other than a boat anchor.
Alvin
It looks like dual primary's and dual secondaries. Depending on the winding of it, you might be able to use it for an isolation transformer for an non isolated battery charger. If you wire the primaries in series and the secondaries in parallel you can get a pretty powerful step down transformer.
Did you measure the voltage outputs yet?
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
