Originally Posted by Silvey01
Less pedal means less gas injected into the engine saving you fuel.
More restriction from the throttle body, more pumping losses, less efficient use of fuel.
Just keep you foot out of the pedal because less restriction means your car will be a lot more rev happy.
as has been said, irrelevant at other than close to WOT(thanks Phantom), as the throttle plate causes far more restriction than the intake pipe ever will
