Thread: The Deadly Heat
Old 07-14-2011, 12:19 AM   #27 (permalink)
larrybuck
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
There is more info on the Dirt cheap cooling help post in this same section.
Aside from that, there's no magic cheap cure. I have a CRX also!
When you mentioned sometimes passengers; I instantly read picky female!
The humidity in Idaho is nothing compared to back east. I think you could go with dual from behind fans aimed at each seat, and just try to toughen up!
The best body configuration that lends itself to natural cooling would be a small PU w a sliding rear window. They do wonders!
