Will you be able to do tuft testing?
I think so. I just need to find a 3d person to operate the camera.
Originally Posted by dcb
re: piston speed, if your stroke is 3.4" then you would be at 1133 fpm @ 2000 RPM, but there may be more efficiency up and to the left of that point at partial throttle, really need to see the bsfc map to be sure (then factor in automatic trans weirdness)
My stroke is 3.63 inches, so that would equate to an average piston speed of about 1200 fpm. I probably could go down a bit and not sacrifice engine efficiency (well, not that much, anyway).
But you're right - this thread is about the aerocap, not gearing. Heh.
