Old 07-14-2011, 03:30 PM   #19 (permalink)
orbywan
Originally Posted by ecofreak View Post
By far, the MPGuino is the most easily tailored and available MPG monitor in existence. Here's the OBDuino variant thread, which should at least have some merit or inspiration for you.
Also, great work on the boat-tail! The taper, sure, might be a bit sharp, but for what I know, as long as your bottom taper is less than 15 degrees, you're in the zone. Motorhomes, especially Class A, have always put me off for many reasons (I'm a bit too fond of tents and bicycle touring!), but I appreciate your efforts in ecomodding one.
Thanks for the Guino link, I'll check it out. It's quite likely I'll have to lower the bottom.
"Motorhomes, especially Class A, have always put me off for many reasons (I'm a bit too fond of tents and bicycle touring!), but I appreciate your efforts in ecomodding one.[/QUOTE][/I]"
I know what you mean, I traveled lighter until I started getting older. After that, beat to hell syndrome started sneaking up, I want some walls around me and some comfort. Yeah, I know, wussie.
