Old 07-14-2011, 10:11 PM   #10 (permalink)
NeilBlanchard
Top and side view in DWG format are nearly perfect, these will save you a lot of tracing. They hopefully be to full scale and accurate; as AutoDesk has deemed it wise to change the length of the vectors depending on the scale unit you select. A line is 10 units long, and if you make the units meters, the line becomes 10 meters long, or if you make the units inches, the line becomes 10 inches long. Very strange programing choice, in my opinion.
Yes, working on an iMac is a PITA; I have replaced the hard drive in mine, and upgraded it, as well. I'll wait to get another to get a better video card, thanks.
