Old 07-15-2011, 06:14 PM   #30 (permalink)
Andyb04
My First EG - '95 Honda Civic CX
90 day: 43.06 mpg (US)
For a really cost effective solution, I gotta think the extended lug bolts makes the most sense. $70 for zip ties? Lug bolts should be cheaper than that, right? The only problem I see is how to tighten the lugs when you can't use a socket because of the length, and it's recessed into the wheel so you can't use a wrench?
But just extend 2 lug bolts and drill 2 holes in your wheel cover. Tighten with another set of nuts. If they get dirty, it's pretty easy to take them off and clean.
