Old 07-15-2011, 11:41 PM   #16 (permalink)
jime57
OurInsight - '06 Honda Insight
Originally Posted by 3-Wheeler View Post
Hi Jim,
I appreciate your enthusiasm, but at those low speeds, adding the tail would only bring another 5 mpg or so to the mix. At 55 mph your estimate of 1.15 would be closer to what the tail adds to efficiency.
I'm starting to understand just how important pulse and glide can be.
Jim.
Yeah, I think you are correct about the improved FE at lower speeds with the boat tail.
I think a skilled P&G driver can achieve remarkable results. My problem with it is that it a lot of work and the Insight already delivers such good FE that I'm usually not in a mood to do the work. I do engine off coasting when I get a good chance, but that is a more passive approach. Did you achieve the 126MPG by using P&G?
