Old 07-16-2011, 10:49 AM   #11 (permalink)
SwamiSalami
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
Originally Posted by camopaint0707 View Post
So is it more fuel efficient to turn on the AC full blast to cool the car then turn it off and then back on when it's hot again or to just leave it one a lower setting to keep the car at a constant cool?
Just to be clear, I NEVER use my A/C's highest setting. What I meant by toggling on and off, while maintaining air circulation, is that I press the A/C button. This is the button with the "snowflake" on it. In other words, I'm likely to leave the setting on "2" throughout my drive. Also, I'm likely to use the "recirculate" setting throughout as well. This is technically not using the air conditioner, unless you've pushed the respective button.
The concept is basically the same as any other method of conservation. By limiting your use of the air conditioner, you are actively conserving fuel.
I hope this helps you understand what I'm talking about. I'm certainly more confused now.
