How much actual research is there on the placebo effect of aeromods? The tests would have to be quite long- we'd need to ABA at least twice with the driver never knowing if the mod was installed or not.
guudasitgets- how long had you been hypermiling when you installed them and how long did they last? I can't believe that flat wheel covers could have had a negative effect on your FE, could you just have gotten better in the meantime?
Originally Posted by sheepdog44
Transmission type Efficiency
Manual neutral engine off.100% @∞MPG <----- Fun Fact.
