Originally Posted by 3-Wheeler
Hi Jim,
Yes, I use a conservative amount of P&G during my drive home.
There are about five places where I coast about 1/8 mile or so with the engine keyed-off.Jim.
Jim, in a strictly technical sense, I'm not sure this coasting, and my same approach, is pulse-and-glide. I have the impression that true P&G involves accelerating at a engine efficient load, usually something aroung 70%, up to the glide speed and then cutting the ignition and coasting. When the car coasts down to the bottom of the P&G target range, then another cycle is initiated. The theory, as I understand it, is that the engine is always operating in its sweet spot. Maybe I'm wrong on the definitions
Anyway, I do some FAS sections with the key off, but it is usually on downhills, or where I'm going to have to give up speed anyway. I don't consider that P&G, but I don't make a claim to be an expert. Whatever the name, my technique does significantly improve MPG.
