Excellent job on the aeromods! You should give Jody a call at dpTuner for an economy tune since you have a PSD. Will still pick up a little power, optimize the shift points in the transmission. If you haven't done the exhaust yet, Hypermax has a good system with a downpipe ( the stock downpipe is crushed from the factory to fit the chassis ) that doesn't cost an arm and a leg. And switch to Evans Coolant.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
