Old 07-18-2011, 04:32 AM   #56 (permalink)
Vekke
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Originally Posted by CigaR007 View Post
Here's my version of an adjustable grille block. Hope it provides some food for thought.
Basically, two solenoids pull the 3 flaps to create an opening, hence providing sufficient cooling to the radiator. The sidewalls are there to provide an improved cooling efficiency.
I would like the flaps to be more distant from the opening, but most solenoids only have a reach of 1 inch or so. A linear actuator is a possibility, but its cost makes it a bit prohibitive for now.
Still haven't decided if the system will be automatic based on coolant temperature or fully manual. This is simply a basic conceptual drawing.
Any thoughts and/or suggestions ?
I think that looks something that might even work on winter, because you can build that without any other slides than the one on the solenoid.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
