Old 07-18-2011, 10:40 AM   #17 (permalink)
redyaris
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
Low&Slow
I see your 90 day mpg going up slowly, so how is the project going?
I am working on the air inlet for the radiator on the VT500. What needs to be done is quit simple; duct the right amount of air through the radiator for effective cooling and minimum drag, it's the actual doing it that's the problem. I'm directing air that goes between the forks above the front wheel, down past the radiator front face into a chamber that should have a Higher pressure which will drive the air though the radiator. This little detail is taking days to get done due to the proximity of the front wheel and the rotating forks... I have also built a new under tray mount that is much more rigid than the older design. Next on the agenda is the rear license plate mount extension, which will be part of the support structure for the rear aero-bodywork.
