Old 07-18-2011, 10:31 AM   #7 (permalink)
oil pan 4
The Holset HE351VE is perfectly at home putting out over 30psi. I have the compressor map with hand writen notes on the front and back taped up in my wall locker.
I briefly looked at the H35 and HX40 serries.
The H35 seemed too small. The HX40 and HE351VE share the same compressor but the 351 has VGT and a smaller turbine than the 40.
The reason why compression is so high is because originially I didn't plan on running a turbo. But I think I can work around the higher compression with intercooling and water injection and I wont be running much boost.
