Hi RedYaris, I'm making slow progress with the Vision. I rejetted the carbs to see if it would run Ok with leaner jetting but the jury is out until I see if there is an FE improvement. It definitely doesn't accelerate as well as it did before the change. I trimmed back the rear of rear fender and it seems to help the sidewind wobbing. Next up would be mounting smaller mirrors and turnsignals. I also checked my valves and changed the sparkplugs. I seem to be getting 57-58 mpg pretty regularly and need a bit more to break through into the 60 mpg range on a regular basis.
all the best, L&S
