I'm not getting it trooper. If it isn't dual fuel, "dedicated" is implied, i.e. "dedicated gasoline". The form says "check one", of which CNG is an option and gasoline is not. There are no provisions for dual fuel, likely because they cannot guarantee you will use the preferred fuel as has been mentioned.
The fueleconomy site lists the truck as CNG, it isn't dual fuel as far as I can tell. They have Dual Fuel trucks, but they are not on the form.
