Thread: Ducted Radiator
Old 07-19-2011, 08:57 PM   #3 (permalink)
graydonengineering
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
Originally Posted by busypaws View Post
You said "ducted" that got me thinking... How about a furnace vent used on forced air furnace in a home (12x8 inches, couldn't be more then $10 dollars at Home Depot) They have levers on them to open and close. Run a cable next to the hood release cable then you can open/close the vent from the drivers seat.
Yes, only problem is, the luvers will give a fair amount of restriction requireing a larger opening for the same cooling effect. That would be a fast simple solution though.
You could also make a single paddle on a horizontal shaft actuatated by a cable exactly like a throttle body. When in the horizontal "wide open" position, it would cause very little restriction.
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
