...the necessary "logic" sequence (2-digit digital control logic) would be:
0 0 = power-on RESET
1 0 = fan(s) are on
0 1 = speed >30-35 mph
1 1 = (a) fan(s) on & (b) speed>30-35 mph
...a single OR-gate will do the job. Here's how the OR-gate control logic would output "follow" the fan & speed inputs:
0 0 = 0 = OFF, shutters are closed.
0 1 = 1 = ON, shutters are commanded to open.
1 0 = 1 = ON, shutters are commanded to open.
1 1 = 1 = ON, shutters are commanded to open.
...where the two inputs are: 0 = no voltage, and 1 = 12VDC, etc.
...or, you could even have it respond as:
0 1 = 1 = ON, one shutter is commanded to open.
1 0 = 1 = ON, other shutter is commanded to open.
1 1 = 1 = ON, both shutters are commanded to open.
