Thread: crazy idea ?
Old 07-20-2011, 11:18 AM   #29 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
re: pushrod suspension, you are adding sprung weight though, in the form of a pushrod and a bellcrank. AFAIKT it does allow a progressive "spring rate" without progressive springs (as do other non-pushrod/rocker geometries), but still it is extra weight between the spring and the road and thus "sprung weight", just like a pushrod engine needs the pushrods and rockers to be moved by the valve springs half the time.
Unless spring tension increases non-linearly (and dramatically) with weight, I don't see the "reduce unsprung" weight argument as valid, not yet anyway.
