I am fully planning on intercooling and running water injecion continously anytime under load (anything above 2 or 3 psi of boost). I could top out at 8-12lb of boost.
I have an EGT and will install a boost gauge. I am even going to go so far as to install a drive pressure gauge at least during testing.
Also I installed the 92+ cooling system minus the belt driven pump. I am also going to add another coolant bypass to get even more flow though the block.
Note from the future: The engine and HE351VE have no problems dealing with 14 to 15 psi.
Reason: 15psi
