Old 07-22-2011, 12:08 PM   #64 (permalink)
graydonengineering
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Nissan Frontier XE
90 day: 27.87 mpg (US)
Originally Posted by CigaR007 View Post
Good question.. I have no clue at the moment. Looking for something that would make it easily detachable/attachable.
You could mount a threaded insert on the underside of the bumper, drill a hole through the foam alaigned to the insert, and run a long bolt, up from the bottom. a 5/16" button head cap screw can be had in very long lengths and has a very minimalist head. You could even get one in nylon which myght wrok well in this case. You would want to install some type of sleve in the hole through the foam to maintain accurate alignment. That would be the cleanest way I can think of.
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
The Following 2 Users Say Thank You to graydonengineering For This Useful Post:
aerohead (07-30-2011), ECONORAM (05-05-2012)
