The EPA FE test are for the perpose of comparing vehicals against a standardized test. The only way to get the same outcome is to drive in the same pattern as the test cycle. There is no way to get a test of this sort that will suit every situation or driver.
Every publication about the fuel consumption of motor vehicles says the same thing... your fuel consumption may vary based on...
