Originally Posted by dcb
saw this, but it reads like weight is a bigger factor
MIKE KLOEBER'S NITRO UNIVERSITY - COURSE 2, THE DRAGSTER BODY AND AERODYNAMICS
with cars that push 300mph, and that cover a lot of ground at higher speeds, I have to wonder.
i.e. you cannot ignore that big blue plume of low pressure behind the car without considering a boat tail, that low pressure is acting on the rear of the vehicle and is going to be pulling the car back for a large part of the track, exponential with speed.
Something Paul Jaray wrote about long ago,with respect to race cars,was that the open rear wheels are good for directional stability because of their drogue affect( a transom if you will ).
If the rear wheels are enclosed or streamlined,then a vertical rear fin is absolutely mandatory.
At present,the 'draggy' wrinkle-walls are providing a stabilizing effect.
The added mass of the boat tail will have to factored along with the additional mass of the new fin when calculating F= MA.
