Originally Posted by Old Tele man
...you can do the same/similar "improvement" with 'shots' of NOX too, because I all you're doing is introducing a different fuel into the combustion process, one that either "boosts" power (NOX) or economy (CNG, propane, etc.).
...however, the REAL effect is simply that you're adding more fuel, albeit a different fuel, into the engine.
...add both fuels together, and your net "gain" is seldom above zero.
NOX, propane, CNG are for p#$$%. real men use ether
