as for flat towing you genesis im pretty sure you cant. i work as a mechanic for hyundai and own three none of mine can be flat towed and every time some one asks and i look it up on the hyundai service site it says no . and to your question will shifting into neutral hurt your vehicle. answer is no if it would damage it in anyway the transmission control module wouldnt let the trans shift. im not saying it wont let you put it in reverse while in forward. but if you try to downshift from say 5th to 2 at certain speeds the pcm/tcm take over and hold it in a higher gear until engine rpm lower and then down shifts again. if you cant find it in your owners manual i'll look it up for you.
