Old 05-12-2008, 01:48 PM   #3 (permalink)
EngineeredCivic
Originally Posted by JohnnyGrey View Post
If you have an auto, forget about it.
Even if you've got a manual, the ratios may be different on the HX.
At the very least the heads are different (vtec-e), the O2 sensor and the ECU as well.
Mine is a manual. Can the heads, ECU be swapped? Looks like it has higher compression. Maybe I can just pull the stock head and shave it some?
1996 Civic DX - 140,000 miles and still sipping gas
