Old 07-23-2011, 10:27 PM   #21 (permalink)
trooper Tdiesel
live, breath, Isuzu-Ds
trooper Tdiesel's Avatar
puddle jumper - '93 Suzuki sidekick base model
energizer bunny - '86 isuzu trooper base model
Clifford the big red dog - '84 GM S-10 durango
Originally Posted by SentraSE-R View Post
If you have a luxury car, you're hosed, because it will run the AC all the time (within its duty cycle), mixing heat with the cold air in the Summer to regulate temperature, and running the AC to dehumidify the heater air during the Winter.
yes high end cars will default to A\C on.
but ive yet to find one that has no loop hole back door,
set it to feet and turn the A\C butten off. but the moment you turn it back to defrost or turn the engine off/on the A\C resets to being on.
in short, any auto base model or high end, with working A\C set to defrost has it running, weather the A\C butten is pushed or not
thus why if you have it on the floor mode with A\C butten off and it starts raining. you flip it to defrost and it automatically turns the A\C on to deumidafy the window. weather you want it too or not this is happening
well ok ive yet to find one, so there may be one out there that does not. but im gessin theres very few of them, if any.
also the only difference in normal to MAX A\C mode is that normal mode is fresh air
and MAX mode is reticulate mode
MAX is not in any way a higher out put, other then cooling the same air in the cab.
1 86 T\D trooper with rare GEN 3 rods TRANS FIXED NOW DD
1 86 4WD 5sp pup is 2.3L gas, but plan on 2.2L diesel repower
1 91 trop, long term plan is a group buy of imported Isuzu 4JB1-T 2.8L I-4 engines, hoping to get price down to 2K not 3K plus
1993 sidekick my MPG toy, epa rating 26.
i get 29/31 with stock drive train.
