Old 07-24-2011, 02:46 AM   #39 (permalink)
deathtrain
Black Knight - '94 Toyota Corolla
90 day: 58.53 mpg (US)
well I looked and no skirts for me, the body shape just isn't there on the car. So it looks like i am going to just have to fill the tire gap in the wheel well and run some smoothies. I also was able to get a good look under the car and looks good for the belly pan. I have two frame rails the are about 8-10 inches away from the exhaust on both sides. So i will 1) attach something that spans the bridge then belly pan the whole thing. 2) just go from the frame rail to the out side of the body.
Now the grill block is a different story. The upper is not a problem I am Just going to duct tape it up and be done with it. The lower is different. the lower grill block is where 70% of my cooling venting is at on the car.
So I had some pipe wrap from this winter that I will attach to the bottom. then we will see how the temps do. you cant see in the picture but there is a piece of plastic that goes through the middle of the lower and then i has support plastic every 4 inches.
**EDIT** upper grill is now taped up and moon disc are on the way.
