FLA batteries have a fairly intensive maintenance routine, charge level, water quality and level, corrosion, cables, and even more so when sitting idle and in cold climates. Might be a good application for Super-capacitors, charge up quick when you need to go to Home Depot, regen brake assist, light weight.
